Tracking categories
Jump to: navigation, search
This page lists tracking categories which are automatically populated by the MediaWiki software. Their names can be changed by altering the relevant system messages in the MediaWiki namespace.
Tracking category Message name Category inclusion criteria
Pages indexées(empty)index-categoryThe page has a __INDEX__ on it (and is in a namespace where that flag is allowed), and hence is indexed by robots where it normally wouldn't be.
Pages non indexées(empty)noindex-categoryThe page is not indexed by robots because it has the magic word __NOINDEX__ on it and is in a namespace where that flag is allowed.
Pages utilisant des arguments dupliqués dans les appels de modèle(empty)duplicate-args-categoryThe page contains template calls that use duplicates of arguments, such as {{foo|bar=1|bar=2}} or {{foo|bar|1=baz}}.
Pages avec trop d'appels dispendieux aux fonctions de l'analyseur syntaxique(empty)expensive-parserfunction-categoryThe page uses too many expensive parser functions (like #ifexist). See Manual:$wgExpensiveParserFunctionLimit.
Pages contenant des paramètres de modèle non évalués(empty)post-expand-template-argument-categoryThe page is bigger than $wgMaxArticleSize after expanding a template argument (something in triple braces, like {{{Foo}}}).
Pages contenant trop d'inclusions de modèles(empty)post-expand-template-inclusion-categoryThe page size is bigger than $wgMaxArticleSize after expanding all the templates, so some templates were not expanded.
Catégories cachées(empty)hidden-category-categoryThe category contains __HIDDENCAT__ in its page content, which prevents it from showing up in the category links box on pages by default.
Pages avec des liens de fichiers brisés(7 P, 1 F)broken-file-categoryThe page contains a broken file link (a link to embed a file when the file does not exist).
Pages dépassant le nombre de nœuds maximal(empty)node-count-exceeded-categoryThe page exceeds the maximum node count.
Pages dépassant la profondeur d'expansion maximale(empty)expansion-depth-exceeded-categoryThe page exceeds the maximum expansion depth.
Pages avec des titres d'affichage ignorés(empty)restricted-displaytitle-ignoredThe page has an ignored {{DISPLAYTITLE}} because it is not equivalent to the page's actual title.
Pages utilisant des balises HTML auto-fermantes non valides(empty)deprecated-self-close-categoryThe page contains invalid self-closed HTML tags, such as <b/> or <span/>. The behavior of these will change soon to be consistent with the HTML5 specification, so their use in wikitext is deprecated.
Pages avec des boucles de modèle(empty)template-loop-categoryThe page contains a template loop, ie. a template which calls itself recursively.
Pages avec des erreurs de référence(empty)cite-tracking-category-cite-errorPages in this category have errors in the usage of references tags.
Pages avec des erreurs de coloration syntaxique(3 P)syntaxhighlight-error-categoryThere was an error when attempting to highlight code included on the page.
