Trender OPNFV
Trender OPNFV
The tuto explains how to build your own OPNFV trender.
This trender has been shown during OPNFV Plugfest in Paris.
What is needed
- 3mm MDF or plywood
- a Wemos D1 mini [1] : a micro controler arduino-like including a wifi chipset
- a 7 neopixel led [2]: you can of course use less leds, there are possible shields with 1 or 4. 7 can be interesting to play with light within the box
- Soldering iron
- a USB cable (power)
- Time..
The boxes
I created very basic simple boxes. The RLD file used by the laser cutter can be found on fablab github:
It basic basic shapes including
- regular box
- some support for the electonic
- a styroglass support for the light (No product with Chlorine)
We use the laser cutter to cut and engave the box and the styroglass support.
You can obviously customized it according to your needs.
