WemosTTGO
Terminal Lora
- en direct
Moniteur série à 115200 bauds
et avec ce code on voit des paquets arriver
- dans Data
- via mqtt
$ APP_ACCESS_KEY=ttn-account-v2.XXXXXX # récupérée dans l'interface TTN/Applications/wemostangi $ mosquitto_sub -h eu.thethings.network -t '+/devices/+/up' -u 'wemostangi' -P "$APP_ACCESS_KEY" -v --cafile ~/sources/LoRa/mqtt-ca.pem -p 8883 wemostangi/devices/wemos1/up {"app_id":"wemostangi","dev_id":"wemos1","hardware_serial":"003FF0004014FF87","port":1,"counter":26,"payload_raw":"SGVsbG8sIHdvcmxkIQ==","payload_fields":{"message":"Hello, world!"},"metadata":{"time":"2018-11-19T17:41:34.533665527Z","frequency":867.7,"modulation":"LORA","data_rate":"SF7BW125","airtime":61696000,"coding_rate":"4/5","gateways":[{"gtw_id":"eui-fcc23dfffe106153","timestamp":2881267900,"time":"2018-11-19T17:41:34.521945Z","channel":6,"rssi":-103,"snr":7.5,"rf_chain":0,"latitude":48.XXX,"longitude":-3.XXX,"altitude":43}]}}
Émission
Pour cela, soit :!
- via mqtt :
$ APP_ACCESS_KEY=ttn-account-v2.XXXXX $ mosquitto_pub -h eu.thethings.network -t 'wemostangi/devices/wemos1/down' -u 'wemostangi' -P "$APP_ACCESS_KEY" --cafile ~/sources/LoRa/mqtt-ca.pem -p 8883 -m '{"payload_raw": "AQ=="}'
# encode la valeur 1 (ie: le nombre 1, pas le caractère 1) $ echo -ne "\x1"| base64 AQ== # décode une payload et l'affiche sous forme lisible (nome et caractère si affichable) $ echo -n "AQ=="|base64 -d|hexdump -C 00000000 01 |.| 00000001
Ajout GPS
http://www.lucadentella.it/en/2017/11/13/esp32-27-gps/
doc
pinout [1]
