GW Kerlink
Sauter à la navigation Sauter à la recherche
  • Prendre un PC fablab, se connecter en filaire
  • nmap -p 33 192.168.128.*
  • ssh root@192.168.128.56
  • pwd root ou pdmk-290000bb
  • /mnt/fsuser-1/ttn
contient les fichiers de config suivre les instructions de :
https://github.com/TheThingsNetwork/packet_forwarder/blob/master/docs/INSTALL_INSTRUCTIONS/KERLINK.md
Commandes passées
scp * root@192.168.0.17:/mnt/fsuser-1/ttn-packet-forwarder puis sur la GW elle même : ./create-package.sh packet-forwarder GW id : eui-0000000000024b08 GW Key : A récupérer sur TTN ... Mais c'est KO
Build utilisé
INFO Got build information BuildDate=2017-06-07T07:5631Z Commit=b64203b985c02a82ab4f3cb41d907be85fcb04e6 Version=
[root@Wirnet_290000bb ttn-packet-forwarder]# ./packet-forwarder start
 INFO Packet Forwarder for LoRa Gateway        HALVersionInfo=Version: 4.0.0; Options: native;
ERROR Failed to find gateway specified as gateway ID AuthServer=https://account.thethingsnetwork.org GatewayID=eui-0000000000024b08 error=Get https://account.thethingsnetwork.org/api/v2/gateways/eui-0000000000024b08: dial tcp 104.40.216.89:443: getsockopt: connection timed out
FATAL Couldn't read configuration              error=Get https://account.thethingsnetwork.org/api/v2/gateways/eui-0000000000024b08: dial tcp 104.40.216.89:443: getsockopt: connection timed out
donc tentative avec scp dota_thethingsnetwork_v1.3_EU.tar.gz root@192.168.0.17:/mnt/fsuser-1/dota puis reboot tcpdump -AUq port 1700 donne enfin un résultat !
[root@Wirnet_290000bb thethingsnetwork]# ./poly_pkt_fwd
semble OK et la GW est sur la carte !
Commande passée et log de démarrage
      • Poly Packet Forwarder for Lora Gateway ***
Version: 2.1.0
      • Lora concentrator HAL library version info ***
Version: 3.1.0; Options: native;
INFO: Little endian host INFO: found global configuration file global_conf.json, parsing it INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters INFO: lorawan_public 1, clksrc 1 INFO: Configuring TX LUT with 16 indexes INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1 INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0 INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12 INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7 INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters INFO: gateway MAC address is configured to AA555A0000000000 INFO: server hostname or IP address is configured to "iot.semtech.com" INFO: upstream port is configured to "1680" INFO: downstream port is configured to "1680" INFO: downstream keep-alive interval is configured to 10 seconds INFO: statistics display interval is configured to 30 seconds INFO: upstream PUSH_DATA time-out is configured to 100 ms INFO: packets received with a valid CRC will be forwarded INFO: packets received with a CRC error will NOT be forwarded INFO: packets received with no CRC will NOT be forwarded INFO: GPS serial port path is configured to "/dev/nmea" INFO: GPS is disabled INFO: Upstream data is enabled INFO: Downstream data is enabled INFO: Ghoststream data is disabled INFO: Radiostream data is enabled INFO: Statusstream data is enabled INFO: Beacon is enabled INFO: Monitor is enabled INFO: found local configuration file local_conf.json, parsing it INFO: redefined parameters will overwrite global parameters INFO: local_conf.json does not contain a JSON object named SX1301_conf INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters INFO: gateway MAC address is configured to 0000024B080000BB INFO: server hostname or IP address is configured to "router.eu.thethings.network" INFO: upstream port is configured to "1700" INFO: downstream port is configured to "1700" INFO: packets received with a valid CRC will be forwarded INFO: packets received with a CRC error will NOT be forwarded INFO: packets received with no CRC will be forwarded INFO: GPS is enabled INFO: Upstream data is enabled INFO: Downstream data is enabled INFO: Ghoststream data is disabled INFO: Radiostream data is enabled INFO: Statusstream data is enabled INFO: Beacon is enabled INFO: Monitor is enabled INFO: [main] TTY port /dev/nmea open for GPS synchronization INFO: [main] Starting the concentrator INFO: [main] concentrator started, radio packets can now be received. WARNING: [gps] GPS out of sync, keeping previous time reference WARNING: [gps] GPS out of sync, keeping previous time reference
          1. 2018-01-07 21:41:38 GMT #####
      1. [UPSTREAM] ###
  1. RF packets received by concentrator: 0
  2. CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
  3. RF packets forwarded: 0 (0 bytes)
  4. PUSH_DATA datagrams sent: 0 (0 bytes)
  5. PUSH_DATA acknowledged: 0.00%
      1. [DOWNSTREAM] ###
  6. PULL_DATA sent: 3 (0.00% acknowledged)
  7. PULL_RESP(onse) datagrams received: 0 (0 bytes)
  8. RF packets sent to concentrator: 0 (0 bytes)
  9. TX errors: 0
      1. [GPS] ###
  10. Valid gps time reference (age: 2 sec)
  11. GPS coordinates: latitude 48.65884, longitude -3.44518, altitude 100 m
          1. END #####
          1. 2018-01-07 21:42:08 GMT #####
      1. [UPSTREAM] ###
  4. PUSH_DATA datagrams sent: 1 (154 bytes)
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  10. Valid gps time reference (age: 0 sec)
  11. GPS coordinates: latitude 48.65884, longitude -3.44521, altitude 103 m
          1. END #####
          1. 2018-01-07 21:42:38 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  10. Valid gps time reference (age: 1 sec)
  11. GPS coordinates: latitude 48.65884, longitude -3.44522, altitude 103 m
          1. END #####
          1. 2018-01-07 21:43:08 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  11. GPS coordinates: latitude 48.65886, longitude -3.44524, altitude 101 m
          1. END #####
NOTE: [down] beacon ready to send (frequency 0 Hz) --- Beacon payload --- 0xEE - 0xFF - 0xC0 - 0x00 - 0x00 - 0x00 - 0x00 - 0x84 0x00 - 0x80 - 0x94 - 0x52 - 0x5A - 0x00 - 0x00 - 0xCE 0xF1 - 0x00 - 0x00 - 0x00 - 0x00 - 0x00 - 0x00 - 0x00 --- end of payload --- NOTE: [down] beacon sent successfully
          1. 2018-01-07 21:43:38 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
          1. END #####
          1. 2018-01-07 21:44:08 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  11. GPS coordinates: latitude 48.65886, longitude -3.44523, altitude 101 m
          1. END #####
          1. 2018-01-07 21:44:38 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  11. GPS coordinates: latitude 48.65886, longitude -3.44522, altitude 101 m
          1. END #####
          1. 2018-01-07 21:45:08 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  11. GPS coordinates: latitude 48.65885, longitude -3.44522, altitude 101 m
          1. END #####
NOTE: [down] beacon ready to send (frequency 0 Hz) --- Beacon payload --- 0xEE - 0xFF - 0xC0 - 0x00 - 0x00 - 0x00 - 0x00 - 0x84 0x00 - 0x00 - 0x95 - 0x52 - 0x5A - 0x00 - 0x00 - 0xCE 0xF1 - 0x00 - 0x00 - 0x00 - 0x00 - 0x00 - 0x00 - 0x00 --- end of payload --- NOTE: [down] beacon sent successfully
          1. 2018-01-07 21:45:38 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  11. GPS coordinates: latitude 48.65885, longitude -3.44521, altitude 102 m
          1. END #####
          1. 2018-01-07 21:46:08 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
          1. END #####
          1. 2018-01-07 21:46:38 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  11. GPS coordinates: latitude 48.65885, longitude -3.44521, altitude 101 m
          1. END #####
          1. 2018-01-07 21:47:08 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
          1. END #####
          1. 2018-01-07 21:47:38 GMT #####
      1. [UPSTREAM] ###
      1. [DOWNSTREAM] ###
  9. TX errors: 0
      1. [GPS] ###
  11. GPS coordinates: latitude 48.65884, longitude -3.44519, altitude 105 m
          1. END #####
cat global_conf.json :
	"SX1301_conf": {
		"lorawan_public": true,
		"clksrc": 1, /* radio_1 provides clock to concentrator */
		"radio_0": {
			"enable": true,
			"type": "SX1257",
			"freq": 867500000,
			"rssi_offset": -166.0,
			"tx_enable": true
		"radio_1": {
			"enable": true,
			"type": "SX1257",
			"freq": 868500000,
			"tx_enable": false
		"chan_multiSF_0": {
			/* Lora MAC channel, 125kHz, all SF, 868.1 MHz */
			"enable": true,
			"radio": 1,
			"if": -400000
		"chan_multiSF_1": {
			/* Lora MAC channel, 125kHz, all SF, 868.3 MHz */
			"enable": true,
			"radio": 1,
			"if": -200000
		"chan_multiSF_2": {
			/* Lora MAC channel, 125kHz, all SF, 868.5 MHz */
			"enable": true,
			"radio": 1,
			"if": 0
		"chan_multiSF_3": {
			/* Lora MAC channel, 125kHz, all SF, 867.1 MHz */
			"enable": true,
			"radio": 0,
			"if": -400000
		"chan_multiSF_4": {
			/* Lora MAC channel, 125kHz, all SF, 867.3 MHz */
			"enable": true,
			"radio": 0,
			"if": -200000
		"chan_multiSF_5": {
			/* Lora MAC channel, 125kHz, all SF, 867.5 MHz */
			"enable": true,
			"radio": 0,
			"if": 0
		"chan_multiSF_6": {
			/* Lora MAC channel, 125kHz, all SF, 867.7 MHz */
			"enable": true,
			"radio": 0,
			"if": 200000
		"chan_multiSF_7": {
			/* Lora MAC channel, 125kHz, all SF, 867.9 MHz */
			"enable": true,
			"radio": 0,
			"if": 400000
		"chan_Lora_std": {
			/* Lora MAC channel, 250kHz, SF7, 868.3 MHz */
			"enable": true,
			"radio": 1,
			"if": -200000,
			"bandwidth": 250000,
			"spread_factor": 7
		"chan_FSK": {
			/* FSK 50kbps channel, 868.8 MHz */
			"enable": true,
			"radio": 1,
			"if": 300000,
			"bandwidth": 125000,
			"datarate": 50000
                "tx_lut_0": {
                        /* TX gain table, index 0 */
                        "pa_gain": 0,
                        "mix_gain": 8,
                        "rf_power": -5,
                        "dig_gain": 0
                "tx_lut_1": {
                        /* TX gain table, index 1 */
                        "pa_gain": 0,
                        "mix_gain": 11,
                        "rf_power": -1,
                        "dig_gain": 0
                "tx_lut_2": {
                        /* TX gain table, index 2 */
                        "pa_gain": 0,
                        "mix_gain": 12,
                        "rf_power": 0,
                        "dig_gain": 0
                "tx_lut_3": {
                        /* TX gain table, index 3 */
                        "pa_gain": 1,
                        "mix_gain": 9,
                        "rf_power": 7,
                        "dig_gain": 0
                "tx_lut_4": {
                        /* TX gain table, index 4 */
                        "pa_gain": 1,
                        "mix_gain": 10,
                        "rf_power": 8,
                        "dig_gain": 0
                "tx_lut_5": {
                        /* TX gain table, index 5 */
                        "pa_gain": 1,
                        "mix_gain": 12,
                        "rf_power": 11,
                        "dig_gain": 0
                "tx_lut_6": {
                        /* TX gain table, index 6 */
                        "pa_gain": 1,
                        "mix_gain": 13,
                        "rf_power": 13,
                        "dig_gain": 0
                "tx_lut_7": {
                        /* TX gain table, index 7 */
                        "pa_gain": 1,
                        "mix_gain": 14,
                        "rf_power": 14,
                        "dig_gain": 0
                "tx_lut_8": {
                        /* TX gain table, index 8 */
                        "pa_gain": 2,
                        "mix_gain": 9,
                        "rf_power": 16,
                        "dig_gain": 0
                "tx_lut_9": {
                        /* TX gain table, index 9 */
                        "pa_gain": 2,
                        "mix_gain": 11,
                        "rf_power": 19,
                        "dig_gain": 0
                "tx_lut_10": {
                        /* TX gain table, index 10 */
                        "pa_gain": 3,
                        "mix_gain": 8,
                        "rf_power": 21,
                        "dig_gain": 0
                "tx_lut_11": {
                        /* TX gain table, index 11 */
                        "pa_gain": 3,
                        "mix_gain": 8,
                        "rf_power": 23,
                        "dig_gain": 0
                "tx_lut_12": {
                        /* TX gain table, index 12 */
                        "pa_gain": 3,
                        "mix_gain": 9,
                        "rf_power": 24,
                        "dig_gain": 0
                "tx_lut_13": {
                        /* TX gain table, index 13 */
                        "pa_gain": 3,
                        "mix_gain": 10,
                        "rf_power": 26,
                        "dig_gain": 0
                "tx_lut_14": {
                        /* TX gain table, index 14 */
                        "pa_gain": 3,
                        "mix_gain": 11,
                        "rf_power": 27,
                        "dig_gain": 0
                "tx_lut_15": {
                        /* TX gain table, index 15 */
                        "pa_gain": 3,
                        "mix_gain": 12,
                        "rf_power": 28,
                        "dig_gain": 0
	"gateway_conf": {
		"gateway_ID": "AA555A0000000000",
		/* change with default server address/ports, or overwrite in local_conf.json */
		"server_address": "iot.semtech.com",
		"serv_port_up": 1680,
		"serv_port_down": 1680,
		/* adjust the following parameters for your network */
		"keepalive_interval": 10,
		"stat_interval": 30,
		"push_timeout_ms": 100,
		/* forward only valid packets */
		"forward_crc_valid": true,
		"forward_crc_error": false,
		"forward_crc_disabled": false,
		/* GPS configuration */
		"gps_tty_path": "/dev/nmea"
[root@Wirgrid_290000bb ttn]# cat local_conf.json {
 "gateway_conf": {
     "gateway_ID": "0000024b08",
     "serv_port_up": 1700,
     "serv_port_down": 1700,
     "server_address": "router.eu.thethings.network",
     "forward_crc_disabled": true,
     "gps": true
cf : https://www.disk91.com/2017/technology/internet-of-things-technology/lets-be-part-of-the-thing-network-with-a-kerlink-lora-iot-station/
https://www.thethingsnetwork.org/docs/gateways/kerlink/config.html
