En cours de réalisation...
epilog
| Modèle | Puiss. Laser (W) | Surface (mm) | Materiaux | Hw/Fw Libre | Logiciel de commande | Prix | ||
| Zing 16 | 30,40 | 406*305 | non | Windows driver, eth/usb | $7,995 (US Price Only) | |||
| Zing 24 | 30,40,50,60 | 610*305 | non idem |
Laserscript
diy
- http://www.buildlog.net/sm_laser/drawings.html
- http://labs.nortd.com/lasersaur/
- axCut
- https://github.com/Axford/axCut
- Quelques infos complémentaire :
| axCut | 40-80W | 850mm x 600mm | oui | RPi/Arduino/Marlin | 2000£ (TBC) | ? |
Liens a explorer...
- http://edutechwiki.unige.ch/en/Laser_cutter : Super source d'infos
- http://www.laseo-tech.com à Lannion !
- forum
- http://www.gravograph.com
- http://www.bodorcnc.com/fr/
comparatif technique
| Nom | Trotec speedy 100 | LaserSaur | AxCut | ja-50 | ja-100 | epilog laser Zing24 | Buildlog.net 2.x Laser | |
| HW | proprietaire | openHW | openHW | proprietaire | proprietaire | proprietaire | openHW | |
| Software | proprietaire | openSW linux | openSW linux | proprietaire | proprietaire | Windows …/7/8 | OpenSW | |
| Documentation | yes | Lasersaur manual | blog | ? | ? | ? | blog | wiki |
| remarque | version HW 14.03/SW 14.11 ident : <y>.<m> |
pas d'évolution depuis plus d'1 ans !! | pas d'évolution depuis plus d'1 ans !! | actif |
- Espace de travail
| Nom | Trotec speedy 100 | LaserSaur | AxCut | ja-50 | ja-100 | "epilog laser Zing24" | Buildlog.net 2.x Laser |
| Dimension | 974x765x457mm | 1700x1170x360mm | ? | 1020x650x600mm | 1480x1000x1080mm | 965x692x381mm | |
| surface de travail | 610x305mm | 1220x610mm | 850x600mm | 300x500mm | 600x900mm | 610x305mm | 300x500x100mm |
| hauteur de piece | 170mm | ? | |||||
| poids | 105kg | 260kg | 64kg | ||||
| resolution | ? | 254 dpi<= 850dpi | ? | <=4500dpi | <=4500dpi | <=1000dpi | |
| Precision | ? | 100µm -30µm | ? | 6µm | 6µm | 25µm | |
| vitesse standard | 180cm/seconde | 13cm/seconde | ? | <=90cm/s | <=90cm/s | ||
| vitesse performance | 280cm/seconde | 20cm/seconde | ? | 90cm/s | 90cm/s |
- Laser
| durée de vie laser | 1500h | 3000h | |||||
| puissance | 12 à 60 Watts | 40W to 80W | 50W | 100W | 30w to 60w | 40W | |
| type | C02 | CO2 | CO2 | CO2 | CO2 | CO2 | CO2 |
| refroidissement | air | air / liquide (80W) | Air / liquide (80W) | liquide | liquide | air | |
| autofocus | yes | no | “yes” / lit motorisé !! | ? | ? | permanent | |
| pointeur laser | yes | no | no | ? | ? | yes | |
| prix tube remplacement | ? | 390ht | 690ht | ||||
| Aspiration | options |
- plan de découpe
| ferromagnétique | options | choix | choix | ? | ? | ? | ? |
| dépression | options | choix | choix | ? | ? | ? | ? |
| honeycomb | options | choix | choix | ? | ? | ? | ? |
- extra:
A noter il existe le site LAOS Laser qui propose de modifier des découpeuses chinoise tels que la HPC LS3020 ou K40 III en refaisant l'électronique et le soft en opensource.
sécurité
- extracteur d'air : > 1000m3/h ou 277 litre/sec !!! - extincteur : poudre / CO2 à proximité - assistance d'air : air compressé ou azote
si lasercut DIY :
- tube: nécessité d'avoir éventuellement un bloc de refroidissement d'eau. (water chiller) suivant puissance. - table : l'ensemble impose d'avoir une table de support pour installer l'extraction / bloc de refroidissement / extincteur(s)
